I was wondering what the easiest way is to have the Core notify an android device, when an input is triggered. This input would be fairly simple just on/off or high or low (analog), for now. Maybe in the future being able to have set point for the analog input to trigger would be great but I would like to start with the basics.
I would also use IFTTT for that - it works quite good for such things … I haved only tried it with a PIR so far but it should really work with all kind of events …
Thanks for the input, IFTTT was the way I was thinking just wanted to make sure i was heading in the right direction. Once I get things figured out I will post back with my results.
Yeah the new IFTTT channel is awesome and a quick way if you just want to grab a notification on your device. I’ve used GCM for stuff integrated into an app, but it requires an intermediary server because Spark can’t handle HTTPS.
Hey so i got every up and running, and i must say it is pretty sweet and simple to get thing communicating. The only thing I need to do now is learn the programming language better, so i can start making some in-depth projects, I am pretty we versed with PLC logic but this style of programming is a whole new ball game for me so far. Here is a sample of my code that I used to have simple push button trigger a notification on my android device (thought others might find this handy if they are just starting to learn as I am).
if (val == LOW)
Spark.publish("X0");
delay(1000);
I used X0 as my variable since I am used to working with inputs/outputs of a PLC. I was getting a response time of about 20 seconds from the time the button was pushed to receiving the notification on my phone through IFTTT.
