Beginner app programmer stuck: ERROR: "specified for property 'quickstartFile' does not exist."
Sorry if this might seem like a dumb question but im just getting into android app programming for particle. I am trying to compile the sdk_example_app but struggling..
So far i have downloaded Andriod Studio and successful run a super basic "hello world" app on an emulator.
Now im trying to compile sdk_example_app but im getting stuck with
"ERROR: No value has been specified for this provider."
I don't really know what to do with that? What provider is it talking about?
Edit: I got a little more help from the terminal by using --info
Could not resolve all artifacts for configuration ':sdk_example_app:classpath'.
Cannot resolve external dependency com.android.tools.build:gradle because no repositories are defined.
Required by:
project :sdk_example_app
Edit 2:
Apparently you also need Android SDK 28 installed. This should probably be in the noob installation instructions. I still can't compile though and getting a bunch of gradle issues.
Are you using the very latest Android Studio?
Thanks, I solved the issue from a github user: The example requires firebase.
