Hello There!
I am building an android app which connects to my particle photon and makes a pin high or low using a toggle button in my app. I checked the reference guide and got the command statement to add to app:build.gradle
compile 'io.particle:cloudsdk:0.4.6'
When I put this statement to my build.gradle file and tried to sync it, I got this error message
Error:Conflict with dependency 'com.google.code.findbugs:jsr305' in project ':app'. Resolved versions for app (3.0.1) and test app (2.0.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Can please anyone guide me what I am supposed to do remove this error?
I forget what I had to change to get rid of that error. It was either the SDK version or editing the androidTestCompile line. In any case, here’s a build.gradle file for a test project that builds properly:
apply plugin: 'com.android.application'
android {
compileSdkVersion 24
buildToolsVersion "25.0.0"
defaultConfig {
applicationId "com.rickk.tempmon10"
minSdkVersion 15
targetSdkVersion 24
versionCode 1
versionName "1.0"
testInstrumentationRunner "android.support.test.runner.AndroidJUnitRunner"
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
dependencies {
compile fileTree(dir: 'libs', include: ['*.jar'])
androidTestCompile('com.android.support.test.espresso:espresso-core:2.2.2', {
exclude group: 'com.android.support', module: 'support-annotations'
compile 'com.android.support:appcompat-v7:24.2.1'
compile 'com.android.support.constraint:constraint-layout:1.0.2'
testCompile 'junit:junit:4.12'
compile 'io.particle:devicesetup:0.4.6'
androidTestCompile 'io.particle:devicesetup:0.4.6'
Hi @rickkas7
I tried your suggestion but now I am getting multiple errors:
Preformatted textError:Conflict with dependency 'com.android.support:support-vector-drawable' in project :app. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Error:Conflict with dependency 'com.android.support:support-v4' in project ':app'. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Error:Conflict with dependency 'com.android.support:appcompat-v7' in project ':app'. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Error:Conflict with dependency 'com.android.support:support-fragment' in project ':app'. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Error:Conflict with dependency 'com.android.support:support-compat' in project ':app'. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Error:Conflict with dependency 'com.android.support:support-media-compat' in project ':app'. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Error:Conflict with dependency 'com.android.support:animated-vector-drawable' in project ':app'. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Error:Conflict with dependency 'com.android.support:support-core-ui' in project ':app'. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Error:Conflict with dependency 'com.android.support:support-annotations' in project ':app'. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
Error:Conflict with dependency 'com.android.support:support-core-utils' in project ':app'. Resolved versions for app (26.0.0-alpha1) and test app (25.3.1) differ. See http://g.co/androidstudio/app-test-app-conflict for details.
And here is my app:build.gradle file,
android {
compileSdkVersion 26
buildToolsVersion "26.0.0"
defaultConfig {
applicationId "com.a09gmail.a23.adityaprakash.particleswitch"
minSdkVersion 15
targetSdkVersion 26
versionCode 1
versionName "1.0"
buildTypes {
release {
minifyEnabled false
dependencies {
compile 'com.android.support:appcompat-v7:26.+'
Please advise me what should I should do to solve this problem.
Try this (removing duplicate findbugs dependency):
dependencies { compile fileTree(dir: 'libs', include: ['*.jar']) androidTestCompile('com.android.support.test.espresso:espresso-core:2.2.2', { exclude group: 'com.android.support', module: 'support-annotations' exclude group: 'com.google.code.findbugs', module: 'jsr305' }) compile 'com.android.support:appcompat-v7:26.0.0' compile 'com.android.support.constraint:constraint-layout:1.0.2' testCompile 'junit:junit:4.12' compile 'io.particle:cloudsdk:0.4.6' //if you need setup sdk compile 'io.particle:devicesetup:0.4.7' }
