Has anyone got this error while creating an Android App.?
This error occurs while I do a “Generate a Signed APK” in Android Studio (v.2.3.2) . I use
compile 'io.particle:devicesetup:0.5.2'. It seems to indicate that Java 8 was used. I tried using
targetCompatibility = '1.8'
sourceCompatibility = '1.8'
but still getting the same error.
Error:Error converting bytecode to dex:
Cause: Dex cannot parse version 52 byte code.
This is caused by library dependencies that have been compiled using Java 8 or above.
If you are using the 'java' gradle plugin in a library submodule add
targetCompatibility = '1.7'
sourceCompatibility = '1.7'
to that submodule's build.gradle file.
...while parsing io/particle/android/sdk/accountsetup/CreateAccountActivity.class
My App. Gradle (v3.3) looks like:
apply plugin: 'com.android.application'
apply plugin: 'me.tatarka.retrolambda'
android {
compileSdkVersion 26
buildToolsVersion '25.0.2'
defaultConfig {
applicationId "com.xxxxx.xxxx"
minSdkVersion 22
targetSdkVersion 24
versionCode 1
versionName "1.0"
aaptOptions {
cruncherEnabled = false
dexOptions {
javaMaxHeapSize "2g"
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
compileOptions {
sourceCompatibility JavaVersion.VERSION_1_7
targetCompatibility JavaVersion.VERSION_1_7
productFlavors {
dependencies {
compile fileTree(include: ['*.jar'], dir: 'libs')
retrolambdaConfig 'net.orfjackal.retrolambda:retrolambda:2.3.0'
