When i create a new app in Android Studio and then add
api ‘io.particle:cloudsdk:0.4.8’ (or higher version)
to my dependencies
my test app instantly crashes with the following error when i try to run in on my phone:
04-22 18:49:10.976 25350-25350/com.example.benja.test E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.example.benja.test, PID: 25350
java.lang.RuntimeException: Unable to instantiate activity ComponentInfo{com.example.benja.test/com.example.benja.test.MainActivity}: java.lang.ClassNotFoundException: Didn’t find class “com.example.benja.test.MainActivity” on path: DexPathList[[zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/base.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_dependencies_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_resources_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_0_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_1_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_2_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_3_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_4_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_5_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_6_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_7_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_8_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_9_apk.apk”],nativeLibraryDirectories=[/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/lib/arm64, /system/lib64, /vendor/lib64]]
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2839)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3030)
at android.app.ActivityThread.-wrap11(Unknown Source:0)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1696)
at android.os.Handler.dispatchMessage(Handler.java:105)
at android.os.Looper.loop(Looper.java:164)
at android.app.ActivityThread.main(ActivityThread.java:6938)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.Zygote$MethodAndArgsCaller.run(Zygote.java:327)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1374)
Caused by: java.lang.ClassNotFoundException: Didn’t find class “com.example.benja.test.MainActivity” on path: DexPathList[[zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/base.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_dependencies_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_resources_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_0_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_1_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_2_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_3_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_4_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_5_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_6_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_7_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_8_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_9_apk.apk”],nativeLibraryDirectories=[/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/lib/arm64, /system/lib64, /vendor/lib64]]
at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:379)
at java.lang.ClassLoader.loadClass(ClassLoader.java:312)
04-22 18:49:10.978 25350-25350/com.example.benja.test E/AndroidRuntime: at android.app.Instrumentation.newActivity(Instrumentation.java:1180)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2829)
… 9 more
Suppressed: java.lang.NoClassDefFoundError: Failed resolution of: Landroid/support/v7/app/AppCompatActivity;
at java.lang.VMClassLoader.findLoadedClass(Native Method)
at java.lang.ClassLoader.findLoadedClass(ClassLoader.java:738)
at java.lang.ClassLoader.loadClass(ClassLoader.java:363)
… 12 more
Caused by: java.lang.ClassNotFoundException: Didn’t find class “android.support.v7.app.AppCompatActivity” on path: DexPathList[[zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/base.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_dependencies_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_resources_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_0_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_1_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_2_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_3_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_4_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_5_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_6_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_7_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_8_apk.apk”, zip file “/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_slice_9_apk.apk”],nativeLibraryDirectories=[/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/lib/arm64, /system/lib64, /vendor/lib64]]
… 15 more
Suppressed: java.io.IOException: Failed to open dex files from /data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_dependencies_apk.apk because: Failure to verify dex file ‘/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_dependencies_apk.apk’: Bad method handle type 7
at dalvik.system.DexFile.openDexFileNative(Native Method)
at dalvik.system.DexFile.openDexFile(DexFile.java:353)
at dalvik.system.DexFile.(DexFile.java:100)
at dalvik.system.DexFile.(DexFile.java:74)
at dalvik.system.DexPathList.loadDexFile(DexPathList.java:374)
at dalvik.system.DexPathList.makeDexElements(DexPathList.java:337)
at dalvik.system.DexPathList.(DexPathList.java:157)
at dalvik.system.BaseDexClassLoader.(BaseDexClassLoader.java:65)
at dalvik.system.PathClassLoader.(PathClassLoader.java:64)
at com.android.internal.os.PathClassLoaderFactory.createClassLoader(PathClassLoaderFactory.java:43)
at android.app.ApplicationLoaders.getClassLoader(ApplicationLoaders.java:69)
at android.app.ApplicationLoaders.getClassLoader(ApplicationLoaders.java:36)
at android.app.LoadedApk.createOrUpdateClassLoaderLocked(LoadedApk.java:676)
at android.app.LoadedApk.getClassLoader(LoadedApk.java:709)
at android.app.LoadedApk.getResources(LoadedApk.java:942)
at android.app.ContextImpl.createAppContext(ContextImpl.java:2303)
at android.app.ActivityThread.handleBindApplication(ActivityThread.java:5937)
at android.app.ActivityThread.-wrap1(Unknown Source:0)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1764)
… 6 more
Suppressed: java.io.IOException: No original dex files found for dex location (arm64) /data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_resources_apk.apk
04-22 18:49:10.979 25350-25350/com.example.benja.test E/AndroidRuntime: at dalvik.system.DexFile.openDexFileNative(Native Method)
… 6 more
[CIRCULAR REFERENCE:java.io.IOException: Failed to open dex files from /data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_dependencies_apk.apk because: Failure to verify dex file ‘/data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_dependencies_apk.apk’: Bad method handle type 7]
[CIRCULAR REFERENCE:java.io.IOException: No original dex files found for dex location (arm64) /data/app/com.example.benja.test-G6b5-IFbBYOxvBb3OzRckQ==/split_lib_resources_apk.apk]
When drop to sdk 0.4.7 the app starts up just fine.
any help would be greatly appreciated
