Failed to resolve io.particle:cloudsdk
I have an old Android App (5 years) which was working with older Android Studio.
Recently I updated Android Studio to "Hedgehog | 2023.1.1" then, an error show up.
Failed to resolve: 'io.particle:cloudsdk:1.0.1'
dependencies {
    implementation  fileTree(include: ['*.jar'], dir: 'libs')
    implementation 'com.google.android.material:material:1.6.0'
    implementation 'androidx.appcompat:appcompat:1.4.1'
    implementation 'androidx.legacy:legacy-support-v4:1.0.0'
    // THE FOLLOWING TO USE A PUBLISHED VERSION OF THE SDK:
    implementation  'io.particle:cloudsdk:1.0.1'
The Android particle sdk isn't supported anymore, but you can download the cloudsdk itself and implement it as a local project. That way you can make the necessary changes to get it to compile if you still needed to go that route.
In build.gradle
implementation project(':cloudsdk')
In settings.gradle
project(':cloudsdk').projectDir = new File('path/to/cloudsdk')
There are still a ton of other androidx changes you'll have to make.
Do you know where I could download the cloudsdk project to build locally ?
OR
a available library which can include locally instead
