Hi , I am using particle boards from past few months this is really cool and amazed with mesh network. But since the board was heated since I had few sensors connected and my barcode got melted and turned black so I’m nt able to scan d device for forming a mesh is there any other method like using particle cli or anything else to form a mesh
Please help me
You can use particle identify which will give you the device ID and the serial number and with these you can rebuild the data matrix.
I'll search the post where the process is explained.
Found the post via the forum search with these search terms: mesh qr code
Here are some more hits
https://community.particle.io/search?q=mesh%20qr%20code
