ScruffR
February 22, 2019, 4:46pm
2
With particle identify any serial terminal program you can read the device ID, serial number and device secret by sending i to the device (in Listening Mode).
With these you can recreate the data matrix with this tool
There were some threads for that issue already
Hey there!
So actually, it is entirely possible to recreate the barcode for any device you have USB access to!
The first thing you’ll want to do is update to the latest available release (at the time of this writing, is 0.8.0-rc.27 . You can flash this over USB while your device is in DFU Mode by using particle flash --usb FILENAME.bin
Afterward, be sure to put the device into listening mode .
Once in listening mode, you will want to go ahead and open a serial connection on your device. (In Wi…
You can use particle identify which will give you the device ID and the serial number and with these you can rebuild the data matrix.
I’ll search the post where the process is explained.
Found the post via the forum search with these search terms: mesh qr code
Here are some more hits
https://community.particle.io/search?q=mesh%20qr%20code
