I am working on my first design integrating the B404. I am referencing the datasheet as well as the evaluation board to try to understand how to power the board.
I am confused by a conflicting item I found, and am looking for clarity.
The B404 evaluation board uses a TI BQ24195L chip to control the input power sources. From what I can tell the BQ24195L outputs 5.1V out of its regulator which after going through a power switch and jumper is connected to UVCC. According to the datasheet of the B404 those pins should see between 3.6-4.3V. I am trying to understand how this works. Any advice would be appreciated.
Thank you!
