Asset Tracker V2 GPS Troubleshoot
I have the Asset tracker V2. I wasn’t getting a GPS fix, so I checked the fuel gauge, found out I was low on battery (maybe that’s the reason), and the RED LED of the Asset tracker was blinking every second (no fix) for a while. I plugged in the USB to start charging the LIPO, GPS LED stopped blinking as if it got a fix but no coordinates are being published. Any help?
I’m using this code:
This example shows a lot of different features. As configured here
it'll check for a good GPS fix every 10 minutes and publish that data
if there is one. If not, it'll save you data by staying quiet. It also
registers 3 Particle.functions for changing whether it publishes,
reading the battery level, and manually requesting a GPS reading.
// Getting the library
#include "AssetTracker/AssetTracker.h"
// Set whether you want the device to publish data to the internet by default here.
// 1 will Particle.publish AND Serial.print, 0 will just Serial.print
// Extremely useful for saving data while developing close enough to have a cable plugged in.
// You can also change this remotely using the Particle.function "tmode" defined in setup()
int transmittingData = 1;
// Used to keep track of the last time we published data
long lastPublish = 0;
// How many minutes between publishes? 10+ recommended for long-time continuous publishing!
int delayMinutes = 1;
// Creating an AssetTracker named 't' for us to reference
AssetTracker t = AssetTracker();
// A FuelGauge named 'fuel' for checking on the battery state
FuelGauge fuel;
// setup() and loop() are both required. setup() runs once when the device starts
// and is used for registering functions and variables and initializing things
    // Sets up all the necessary AssetTracker bits
    t.begin();
    // Enable the GPS module. Defaults to off to save power.
    // Takes 1.5s or so because of delays.
    t.gpsOn();
    // Opens up a Serial port so you can listen over USB
    // These three functions are useful for remote diagnostics. Read more below.
    Particle.function("tmode", transmitMode);
    Particle.function("gps", gpsPublish);
// loop() runs continuously
    // You'll need to run this every loop to capture the GPS output
    FuelGauge fuel;
    float value;
    value = fuel.getVCell();
    //json string
    String output = "{\"VOLTS\": \"" + String(value) + "\"}";
    Particle.publish("LIPO", output);
    CellularSignal sig = Cellular.RSSI();
    Serial.println(sig.rssi);
    delay(1000*60*5);
    t.updateGPS();
    // if the current time - the last time we published is greater than your set delay...
    if(millis()-lastPublish > delayMinutes*60*1000){
        // Remember when we published
        lastPublish = millis();
        //String pubAccel = String::format("%d,%d,%d",t.readX(),t.readY(),t.readZ());
        //Serial.println(pubAccel);
        //Particle.publish("A", pubAccel, 60, PRIVATE);
        // Dumps the full NMEA sentence to serial in case you're curious
        Serial.println(t.preNMEA());
        // GPS requires a "fix" on the satellites to give good data,
        // so we should only publish data if there's a fix
        if(t.gpsFix()){
            // Only publish if we're in transmittingData mode 1;
            if(transmittingData){
                // Short publish names save data!
                Particle.publish("G", t.readLatLon(), 30, PRIVATE);
            // but always report the data over serial for local development
            Serial.println(t.readLatLon());
// Allows you to remotely change whether a device is publishing to the cloud
// or is only reporting data over Serial. Saves data when using only Serial!
// Change the default at the top of the code.
int transmitMode(String command){
    transmittingData = atoi(command);
    return 1;
// Actively ask for a GPS reading if you're impatient. Only publishes if there's
// a GPS fix, otherwise returns '0'
int gpsPublish(String command){
    if(t.gpsFix()){
        // uncomment next line if you want a manual publish to reset delay counter
        // lastPublish = millis();
        return 1;
    else { return 0; }
This line suggests that you still targeting an old system firmware (<0.5.3 - most recent official is 0.6.4) and you may want to use AssetTrackerRK library instead.
Thanks! I’ll include it.
