Asset Tracker Kit V2 3-axis IMU
Just saw the new asset tracker kit V2, there is one confusion in [Specs]
(https://store.particle.io/products/asset-tracker?variant=41492970118). There is mention of a 3-axis IMU but in the datasheet of the shield it is not mentioned at all. Is there really an IMU embedded in the new shield or is it a typo in the specs.
It’s a ADXL362 listed here: https://docs.particle.io/datasheets/particle-shields/#sensor-kit-includes
http://www.analog.com/media/en/technical-documentation/data-sheets/ADXL362.pdf
ADXL362 is an accelerometer not an IMU, also, it is part of the sensor kit, not the asset tracker v2 shield. Asset tracker shield has a LIS3DH accelerometer.
Ah right. My bad! I have passed on the information to the team to have it updated.
