Argon showing up as unknown in particle app
Hi, I have two argons that are showing up as unknown devices in the particle app:
The particle console seems to know what they are:
Does anyone know how to fix this?
Cliff
log from mobile app: https://drive.google.com/open?id=1wRz3NV_hmaLAHp31mbKyD5DYdaQkpcUy
The device argon1 is part of a product. All product devices show up as “Other” or “Unknown” in the mobile apps and build.particle.io.
thanks – that makes sense then.
Is it possible to change the WiFI credentials using the mobile app for an argon device that is part of a product? Or, how is this typically done?
I have implemented a web BT frontent to configure wifi on Argon devices. It works, but is far from polished:
Web frontend:
Device side:
The web UI looks like:
Again, it needs some cleanup work, but posting in case anyone else is interested in a solution like this.
