Argon Pairing with the assisting device fails
Bingo. That solved the SOS. I was using that short piece of code for quite a while in different projects, this time, the OS (because I updated to latest) killed me. Thanks. With that information I will see if I can solve the rest of my Xenon Argon networrk problems.
Unfortunately, without that library, unless there is a workaround, my project is dead as far as using the Particle Argon and Xenon. Shame, it was looking to be a nice project, and I put a lot of time etc into it.
Not Particle’s fault, they are closing safety loopols, but I need to be able to use a DHT22 in my project.
Any Ideas?
There is a workaround and it’s also mentioned in the GitHub issue linked above
