HI all, I’m seeing some intermittent issues with an Argon that seems to sometimes fails to accept the DHCP settings (can see it pop up on the router, be offered an address, but times out ) over Ethernet.
DeviceOS is 3.2.0
I don’t have a minimal code for reproducing at this time (nor can even reliably instiagate it), but have noticed that it seems to have some form of incorrect address resolution.
When it accepts the DHCP settings:
2022-03-21T13:41:47Z : 9760986 : *********** NETWORK SETTINGS ***************
2022-03-21T13:41:47Z : 9760987 : * LocalIP: 192.168.88.250 SubnetMask: 255.255.255.0 GatewayIP: 192.168.88.1 DNSServer: 0.0.0.0 DHCPServer: 0.0.0.0 *
When it fails to bind the settings:
2000-01-01T00:02:07Z : 127882 : *********** NETWORK SETTINGS ***************
2000-01-01T00:02:07Z : 127883 : * LocalIP: 0.0.0.253 SubnetMask: 255.255.255.0 GatewayIP: 0.0.0.1 DNSServer: 0.0.0.0 DHCPServer: 0.0.0.0 *
(These are results from calling Ethernet.localIP /subnetMask etc)
A soft reset (via reset button) doesn’t seem to resolve the issue, but a hard reset (pull power for a duration) does resolve it.
Has anyone else had particular issues with something similar?
Also, is there any particular way to force clearing the existing network settings and re-requesting new ones?
