Argon fast flash green- USB serial ouput issues on a single unit
Hi all,
I’m having some particularly weird behavior with a single argon (out of 4: Let’s call him BOB). I’ve successfully paired it via the app (using the ethernet featherwing), seen it on the particle cloud- but after flashing my application, the device gives the fast flash green “Looking for internet” indication on this particular unit (and does not provide any debug information via usb serial communication) - pretty much regardless of it is connected to a network or not. Same PC, same cable, same software, same setup, other 3 argons: serial debug works, and the device is in dark blue blinking “Listen mode” waiting for a DHCP server to respond.
Now for even more fun, I can successfully put cloud debug on BOB, and can see the results (either via the terminal on the cloud debug page or via a terminal/monitor program)- but flashing my own application goes back to the same behavior: nothing shown and green blinking LEDs.
I’ve tried going through the setup/initialization process again through the app- BOB can connect to the cloud- but again fails after flashing.
I’m not happy with BOB right now.
adding a log from cloud debug:
Connected to USB serial
Disconnected from USB serial, will attempt to reconnect
e[999;999He[6n> 0000001510 [ncp.at] TRACE: > AT
0000001511 [ncp.at] TRACE: < OK
0000002512 [hal] TRACE: NCP ready to accept AT commands
0000002512 [ncp.at] TRACE: > AT+CMUX=0
0000002514 [ncp.at] TRACE: < OK
0000002515 [gsm0710muxer] INFO: Starting GSM07.10 muxer
0000002515 [gsm0710muxer] INFO: Openning mux channel 0
0000002515 [gsm0710muxer] INFO: GSM07.10 muxer thread started
0000002532 [gsm0710muxer] INFO: Openning mux channel 1
0000003799 [ncp.at] TRACE: > AT
0000003801 [ncp.at] TRACE: < OK
0000003802 [ncp.at] TRACE: > AT+CWDHCP=0,3
0000003807 [ncp.at] TRACE: < OK
0000003808 [hal] TRACE: NCP state changed: 1
0000003808 [net.esp32ncp] TRACE: NCP event 1
0000003808 [net.esp32ncp] TRACE: NCP event 3
0000003809 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000003809 [system.nm] TRACE: Interface 4 power state changed: 2
0000003810 [ncp.at] TRACE: > AT+GETMAC=0
0000003814 [ncp.at] TRACE: < +GETMAC: "84:cc:a8:06:a3:14"
0000003814 [ncp.at] TRACE: < OK
0000003815 [gsm0710muxer] INFO: Stopping GSM07.10 muxer
0000003815 [gsm0710muxer] INFO: Gracefully stopping GSM07.10 muxer
0000003815 [gsm0710muxer] INFO: Closing all muxed channels
0000003816 [gsm0710muxer] INFO: Closing mux channel 1
0000003816 [gsm0710muxer] INFO: Muxed channel 2 already closed
0000003817 [gsm0710muxer] INFO: Muxed channel 3 already closed
0000003817 [gsm0710muxer] INFO: Muxed channel 4 already closed
0000005083 [gsm0710muxer] INFO: Sending CLD (multiplexer close down)
0000005085 [gsm0710muxer] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000005086 [gsm0710muxer] INFO: GSM07.10 muxer thread exiting
0000005086 [gsm0710muxer] INFO: GSM07.10 muxer stopped
0000005087 [net.esp32ncp] TRACE: NCP event 3
0000005087 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000005087 [system.nm] TRACE: Interface 4 power state changed: 3
0000005088 [net.esp32ncp] TRACE: NCP event 3
0000005088 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000005088 [system.nm] TRACE: Interface 4 power state changed: 1
0000005089 [hal] TRACE: Deinit modem serial.
0000005089 [net.esp32ncp] TRACE: NCP event 3
0000005089 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000005090 [system.nm] TRACE: Interface 4 power state changed: 3
0000005090 [net.esp32ncp] TRACE: NCP event 3
0000005090 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000005091 [system.nm] TRACE: Interface 4 power state changed: 1
0000005091 [hal] TRACE: NCP state changed: 0
0000005092 [net.esp32ncp] TRACE: NCP event 1
0000005092 [hal] TRACE: Deinit modem serial.
0000005092 [net.esp32ncp] TRACE: NCP event 3
0000005093 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000005093 [system.nm] TRACE: Interface 4 power state changed: 4
0000006400 [ncp.at] TRACE: > AT
0000006401 [ncp.at] TRACE: < OK
0000007402 [hal] TRACE: NCP ready to accept AT commands
0000007402 [ncp.at] TRACE: > AT+CMUX=0
0000007404 [ncp.at] TRACE: < OK
0000007405 [gsm0710muxer] INFO: Starting GSM07.10 muxer
0000007405 [gsm0710muxer] INFO: Openning mux channel 0
0000007405 [gsm0710muxer] INFO: GSM07.10 muxer thread started
0000007409 [gsm0710muxer] INFO: Openning mux channel 1
0000008677 [ncp.at] TRACE: > AT
0000008680 [ncp.at] TRACE: < OK
0000008680 [ncp.at] TRACE: > AT+CWDHCP=0,3
0000008685 [ncp.at] TRACE: < OK
0000008686 [hal] TRACE: NCP state changed: 1
0000008686 [net.esp32ncp] TRACE: NCP event 1
0000008686 [net.esp32ncp] TRACE: NCP event 3
0000008687 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000008687 [system.nm] TRACE: Interface 4 power state changed: 2
0000015222 [app] INFO: Starting Tests!
0000015222 [app] INFO: Platform: Argon
0000015222 [app] INFO: Binary compiled for: 2.1.0
0000015223 [app] INFO: Cloud Debug Release 2.1.4
0000015223 [app] INFO: System version: 2.1.0
0000015224 [app] INFO: Device ID: e00fce68817951089380c1e5
0000015224 [app] INFO: USB power: true, Battery Volage: 4.22
0000015225 [app] INFO: This device could have Ethernet (is 3rd generation)
0000015226 [app] INFO: FEATURE_ETHERNET_DETECTION enabled
0000015226 [app] INFO: Ethernet adapter present
0000015238 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000015243 [net.ifapi] INFO: Netif en2 state UP
0000015247 [net.en] TRACE: Closed MACRAW socket
0000015249 [net.en] TRACE: Opened MACRAW socket, err = 0
0000015249 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000022403 [net.en] INFO: Link up
0000022403 [net.ifapi] INFO: Netif en2 link UP
0000022404 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000022422 [hal] INFO: DNS server list changed
0000022423 [net.ifapi] TRACE: Netif en2 ipv4 configuration changed
0000022424 [system.nm] INFO: State changed: IFACE_LINK_UP -> IP_CONFIGURED
0000022427 [app] INFO: Ethernet ready (has link and IP address 192.168.1.110)
0000022452 [app] INFO: Configured credentials:
0000022454 [app] INFO:   ssid=deimos security=wpa2 cipher=AES or TKIP
0000022455 [app] INFO: Available access points:
0000022456 [ncp.at] TRACE: > AT+CWLAP
0000024960 [ncp.at] TRACE: < OK
0000024961 [app] INFO: Connecting to Wi-Fi
0000024972 [net.ifapi] INFO: Netif wl3 state UP
0000024976 [ncp.at] TRACE: > AT+CWLAP
0000027479 [ncp.at] TRACE: < OK
0000027480 [net.esp32ncp] TRACE: Failed to connect to WiFi: -170
0000027480 [gsm0710muxer] INFO: Stopping GSM07.10 muxer
0000027480 [gsm0710muxer] INFO: Gracefully stopping GSM07.10 muxer
0000027481 [gsm0710muxer] INFO: Closing all muxed channels
0000027481 [gsm0710muxer] INFO: Closing mux channel 1
0000027481 [gsm0710muxer] INFO: Muxed channel 2 already closed
0000027482 [gsm0710muxer] INFO: Muxed channel 3 already closed
0000027482 [gsm0710muxer] INFO: Muxed channel 4 already closed
0000028749 [gsm0710muxer] INFO: Sending CLD (multiplexer close down)
0000028752 [gsm0710muxer] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000028752 [gsm0710muxer] INFO: GSM07.10 muxer thread exiting
0000028752 [gsm0710muxer] INFO: GSM07.10 muxer stopped
0000028753 [net.esp32ncp] TRACE: NCP event 3
0000028753 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000028753 [system.nm] TRACE: Interface 4 power state changed: 3
0000028754 [net.esp32ncp] TRACE: NCP event 3
0000028754 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000028754 [system.nm] TRACE: Interface 4 power state changed: 1
0000028755 [hal] TRACE: Deinit modem serial.
0000028755 [net.esp32ncp] TRACE: NCP event 3
0000028755 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000028756 [system.nm] TRACE: Interface 4 power state changed: 3
0000028756 [net.esp32ncp] TRACE: NCP event 3
0000028757 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000028757 [system.nm] TRACE: Interface 4 power state changed: 1
0000028757 [hal] TRACE: NCP state changed: 0
0000028758 [net.esp32ncp] TRACE: NCP event 1
0000028758 [hal] TRACE: Deinit modem serial.
0000028858 [net.esp32ncp] TRACE: NCP event 3
0000028858 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000028859 [system.nm] TRACE: Interface 4 power state changed: 4
0000030166 [ncp.at] TRACE: > AT
0000030167 [ncp.at] TRACE: < OK
0000031168 [hal] TRACE: NCP ready to accept AT commands
0000031168 [ncp.at] TRACE: > AT+CMUX=0
0000031170 [ncp.at] TRACE: < OK
0000031171 [gsm0710muxer] INFO: Starting GSM07.10 muxer
0000031171 [gsm0710muxer] INFO: Openning mux channel 0
0000031171 [gsm0710muxer] INFO: GSM07.10 muxer thread started
0000031175 [gsm0710muxer] INFO: Openning mux channel 1
0000031179 [ncp.at] TRACE: > AT
0000031181 [ncp.at] TRACE: < OK
0000031182 [ncp.at] TRACE: > AT+CWDHCP=0,3
0000031188 [ncp.at] TRACE: < OK
0000031188 [hal] TRACE: NCP state changed: 1
0000031188 [net.esp32ncp] TRACE: NCP event 1
0000031189 [net.esp32ncp] TRACE: NCP event 3
0000031189 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000031189 [system.nm] TRACE: Interface 4 power state changed: 2
0000031192 [ncp.at] TRACE: > AT+CWLAP
0000033697 [ncp.at] TRACE: < OK
0000033698 [net.esp32ncp] TRACE: Failed to connect to WiFi: -170
0000033698 [gsm0710muxer] INFO: Stopping GSM07.10 muxer
0000033698 [gsm0710muxer] INFO: Gracefully stopping GSM07.10 muxer
0000033699 [gsm0710muxer] INFO: Closing all muxed channels
0000033699 [gsm0710muxer] INFO: Closing mux channel 1
0000033700 [gsm0710muxer] INFO: Muxed channel 2 already closed
0000033700 [gsm0710muxer] INFO: Muxed channel 3 already closed
0000033700 [gsm0710muxer] INFO: Muxed channel 4 already closed
0000034961 [app] INFO: Still trying to connect to Wi-Fi 00:10
0000034967 [gsm0710muxer] INFO: Sending CLD (multiplexer close down)
0000034970 [gsm0710muxer] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000034970 [gsm0710muxer] INFO: GSM07.10 muxer thread exiting
0000034970 [gsm0710muxer] INFO: GSM07.10 muxer stopped
0000034971 [net.esp32ncp] TRACE: NCP event 3
0000034971 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000034971 [system.nm] TRACE: Interface 4 power state changed: 3
0000034972 [net.esp32ncp] TRACE: NCP event 3
0000034972 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000034973 [system.nm] TRACE: Interface 4 power state changed: 1
0000034973 [hal] TRACE: Deinit modem serial.
0000034973 [net.esp32ncp] TRACE: NCP event 3
0000034973 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000034974 [system.nm] TRACE: Interface 4 power state changed: 3
0000034974 [net.esp32ncp] TRACE: NCP event 3
0000034975 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000034975 [system.nm] TRACE: Interface 4 power state changed: 1
0000034975 [hal] TRACE: NCP state changed: 0
0000034976 [net.esp32ncp] TRACE: NCP event 1
0000034976 [hal] TRACE: Deinit modem serial.
0000035076 [net.esp32ncp] TRACE: NCP event 3
0000035076 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000035077 [system.nm] TRACE: Interface 4 power state changed: 4
0000036384 [ncp.at] TRACE: > AT
0000036385 [ncp.at] TRACE: < OK
0000037386 [hal] TRACE: NCP ready to accept AT commands
0000037386 [ncp.at] TRACE: > AT+CMUX=0
0000037388 [ncp.at] TRACE: < OK
0000037389 [gsm0710muxer] INFO: Starting GSM07.10 muxer
0000037389 [gsm0710muxer] INFO: Openning mux channel 0
0000037389 [gsm0710muxer] INFO: GSM07.10 muxer thread started
0000037393 [gsm0710muxer] INFO: Openning mux channel 1
0000037397 [ncp.at] TRACE: > AT
0000037399 [ncp.at] TRACE: < OK
0000037400 [ncp.at] TRACE: > AT+CWDHCP=0,3
0000037405 [ncp.at] TRACE: < OK
0000037406 [hal] TRACE: NCP state changed: 1
0000037406 [net.esp32ncp] TRACE: NCP event 1
0000037406 [net.esp32ncp] TRACE: NCP event 3
0000037407 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000037407 [system.nm] TRACE: Interface 4 power state changed: 2
0000037410 [ncp.at] TRACE: > AT+CWLAP
0000039915 [ncp.at] TRACE: < OK
0000039916 [net.esp32ncp] TRACE: Failed to connect to WiFi: -170
0000039916 [gsm0710muxer] INFO: Stopping GSM07.10 muxer
0000039916 [gsm0710muxer] INFO: Gracefully stopping GSM07.10 muxer
0000039917 [gsm0710muxer] INFO: Closing all muxed channels
0000039917 [gsm0710muxer] INFO: Closing mux channel 1
0000039917 [gsm0710muxer] INFO: Muxed channel 2 already closed
0000039918 [gsm0710muxer] INFO: Muxed channel 3 already closed
0000039918 [gsm0710muxer] INFO: Muxed channel 4 already closed
0000041185 [gsm0710muxer] INFO: Sending CLD (multiplexer close down)
0000041187 [gsm0710muxer] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000041188 [gsm0710muxer] INFO: GSM07.10 muxer thread exiting
0000041188 [gsm0710muxer] INFO: GSM07.10 muxer stopped
0000041189 [net.esp32ncp] TRACE: NCP event 3
0000041189 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000041189 [system.nm] TRACE: Interface 4 power state changed: 3
0000041190 [net.esp32ncp] TRACE: NCP event 3
0000041190 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000041190 [system.nm] TRACE: Interface 4 power state changed: 1
0000041191 [hal] TRACE: Deinit modem serial.
0000041191 [net.esp32ncp] TRACE: NCP event 3
0000041191 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000041192 [system.nm] TRACE: Interface 4 power state changed: 3
0000041192 [net.esp32ncp] TRACE: NCP event 3
0000041193 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000041193 [system.nm] TRACE: Interface 4 power state changed: 1
0000041193 [hal] TRACE: NCP state changed: 0
0000041194 [net.esp32ncp] TRACE: NCP event 1
0000041194 [hal] TRACE: Deinit modem serial.
0000041294 [net.esp32ncp] TRACE: NCP event 3
0000041294 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000041295 [system.nm] TRACE: Interface 4 power state changed: 4
0000042602 [ncp.at] TRACE: > AT
0000042603 [ncp.at] TRACE: < OK
0000043604 [hal] TRACE: NCP ready to accept AT commands
0000043604 [ncp.at] TRACE: > AT+CMUX=0
0000043606 [ncp.at] TRACE: < OK
0000043607 [gsm0710muxer] INFO: Starting GSM07.10 muxer
0000043607 [gsm0710muxer] INFO: Openning mux channel 0
0000043607 [gsm0710muxer] INFO: GSM07.10 muxer thread started
0000043611 [gsm0710muxer] INFO: Openning mux channel 1
0000043615 [ncp.at] TRACE: > AT
0000043617 [ncp.at] TRACE: < OK
0000043618 [ncp.at] TRACE: > AT+CWDHCP=0,3
0000043624 [ncp.at] TRACE: < OK
0000043624 [hal] TRACE: NCP state changed: 1
0000043624 [net.esp32ncp] TRACE: NCP event 1
0000043625 [net.esp32ncp] TRACE: NCP event 3
0000043625 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000043625 [system.nm] TRACE: Interface 4 power state changed: 2
0000043628 [ncp.at] TRACE: > AT+CWLAP
0000044961 [app] INFO: Still trying to connect to Wi-Fi 00:20
0000046133 [ncp.at] TRACE: < OK
0000046134 [net.esp32ncp] TRACE: Failed to connect to WiFi: -170
0000046134 [gsm0710muxer] INFO: Stopping GSM07.10 muxer
0000046134 [gsm0710muxer] INFO: Gracefully stopping GSM07.10 muxer
0000046135 [gsm0710muxer] INFO: Closing all muxed channels
0000046135 [gsm0710muxer] INFO: Closing mux channel 1
0000046135 [gsm0710muxer] INFO: Muxed channel 2 already closed
0000046136 [gsm0710muxer] INFO: Muxed channel 3 already closed
0000046136 [gsm0710muxer] INFO: Muxed channel 4 already closed
0000047403 [gsm0710muxer] INFO: Sending CLD (multiplexer close down)
0000047405 [gsm0710muxer] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000047406 [gsm0710muxer] INFO: GSM07.10 muxer thread exiting
0000047406 [gsm0710muxer] INFO: GSM07.10 muxer stopped
0000047407 [net.esp32ncp] TRACE: NCP event 3
0000047407 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000047407 [system.nm] TRACE: Interface 4 power state changed: 3
0000047408 [net.esp32ncp] TRACE: NCP event 3
0000047408 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000047408 [system.nm] TRACE: Interface 4 power state changed: 1
0000047409 [hal] TRACE: Deinit modem serial.
0000047409 [net.esp32ncp] TRACE: NCP event 3
0000047409 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000047410 [system.nm] TRACE: Interface 4 power state changed: 3
0000047410 [net.esp32ncp] TRACE: NCP event 3
0000047410 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000047411 [system.nm] TRACE: Interface 4 power state changed: 1
0000047411 [hal] TRACE: NCP state changed: 0
0000047412 [net.esp32ncp] TRACE: NCP event 1
0000047412 [hal] TRACE: Deinit modem serial.
0000047512 [net.esp32ncp] TRACE: NCP event 3
0000047512 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000047513 [system.nm] TRACE: Interface 4 power state changed: 4
0000048820 [ncp.at] TRACE: > AT
0000048821 [ncp.at] TRACE: < OK
0000049822 [hal] TRACE: NCP ready to accept AT commands
0000049822 [ncp.at] TRACE: > AT+CMUX=0
0000049824 [ncp.at] TRACE: < OK
0000049825 [gsm0710muxer] INFO: Starting GSM07.10 muxer
0000049825 [gsm0710muxer] INFO: Openning mux channel 0
0000049825 [gsm0710muxer] INFO: GSM07.10 muxer thread started
0000049829 [gsm0710muxer] INFO: Openning mux channel 1
0000049833 [ncp.at] TRACE: > AT
0000049835 [ncp.at] TRACE: < OK
0000049836 [ncp.at] TRACE: > AT+CWDHCP=0,3
0000049842 [ncp.at] TRACE: < OK
0000049842 [hal] TRACE: NCP state changed: 1
0000049842 [net.esp32ncp] TRACE: NCP event 1
0000049843 [net.esp32ncp] TRACE: NCP event 3
0000049843 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000049843 [system.nm] TRACE: Interface 4 power state changed: 2
0000049847 [ncp.at] TRACE: > AT+CWLAP
0000052351 [ncp.at] TRACE: < OK
0000052352 [net.esp32ncp] TRACE: Failed to connect to WiFi: -170
0000052352 [gsm0710muxer] INFO: Stopping GSM07.10 muxer
0000052352 [gsm0710muxer] INFO: Gracefully stopping GSM07.10 muxer
0000052353 [gsm0710muxer] INFO: Closing all muxed channels
0000052353 [gsm0710muxer] INFO: Closing mux channel 1
0000052353 [gsm0710muxer] INFO: Muxed channel 2 already closed
0000052354 [gsm0710muxer] INFO: Muxed channel 3 already closed
0000052354 [gsm0710muxer] INFO: Muxed channel 4 already closed
0000053621 [gsm0710muxer] INFO: Sending CLD (multiplexer close down)
0000053623 [gsm0710muxer] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000053624 [gsm0710muxer] INFO: GSM07.10 muxer thread exiting
0000053624 [gsm0710muxer] INFO: GSM07.10 muxer stopped
0000053625 [net.esp32ncp] TRACE: NCP event 3
0000053625 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000053625 [system.nm] TRACE: Interface 4 power state changed: 3
0000053626 [net.esp32ncp] TRACE: NCP event 3
0000053626 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000053626 [system.nm] TRACE: Interface 4 power state changed: 1
0000053627 [hal] TRACE: Deinit modem serial.
0000053627 [net.esp32ncp] TRACE: NCP event 3
0000053628 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000053628 [system.nm] TRACE: Interface 4 power state changed: 3
0000053628 [net.esp32ncp] TRACE: NCP event 3
0000053629 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000053629 [system.nm] TRACE: Interface 4 power state changed: 1
0000053629 [hal] TRACE: NCP state changed: 0
0000053630 [net.esp32ncp] TRACE: NCP event 1
0000053630 [hal] TRACE: Deinit modem serial.
0000053730 [net.esp32ncp] TRACE: NCP event 3
0000053730 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000053731 [system.nm] TRACE: Interface 4 power state changed: 4
0000054961 [app] INFO: Still trying to connect to Wi-Fi 00:30
0000055037 [ncp.at] TRACE: > AT
0000055038 [ncp.at] TRACE: < OK
0000056039 [hal] TRACE: NCP ready to accept AT commands
0000056039 [ncp.at] TRACE: > AT+CMUX=0
0000056041 [ncp.at] TRACE: < OK
0000056042 [gsm0710muxer] INFO: Starting GSM07.10 muxer
0000056042 [gsm0710muxer] INFO: Openning mux channel 0
0000056043 [gsm0710muxer] INFO: GSM07.10 muxer thread started
0000056046 [gsm0710muxer] INFO: Openning mux channel 1
0000056050 [ncp.at] TRACE: > AT
0000056053 [ncp.at] TRACE: < OK
0000056053 [ncp.at] TRACE: > AT+CWDHCP=0,3
0000056058 [ncp.at] TRACE: < OK
0000056059 [hal] TRACE: NCP state changed: 1
0000056059 [net.esp32ncp] TRACE: NCP event 1
0000056059 [net.esp32ncp] TRACE: NCP event 3
0000056060 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000056060 [system.nm] TRACE: Interface 4 power state changed: 2
0000056063 [ncp.at] TRACE: > AT+CWLAP
0000058568 [ncp.at] TRACE: < OK
0000058569 [net.esp32ncp] TRACE: Failed to connect to WiFi: -170
0000058569 [gsm0710muxer] INFO: Stopping GSM07.10 muxer
0000058569 [gsm0710muxer] INFO: Gracefully stopping GSM07.10 muxer
0000058570 [gsm0710muxer] INFO: Closing all muxed channels
0000058570 [gsm0710muxer] INFO: Closing mux channel 1
0000058570 [gsm0710muxer] INFO: Muxed channel 2 already closed
0000058571 [gsm0710muxer] INFO: Muxed channel 3 already closed
0000058571 [gsm0710muxer] INFO: Muxed channel 4 already closed
0000059838 [gsm0710muxer] INFO: Sending CLD (multiplexer close down)
0000059840 [gsm0710muxer] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000059841 [gsm0710muxer] INFO: GSM07.10 muxer thread exiting
0000059841 [gsm0710muxer] INFO: GSM07.10 muxer stopped
0000059842 [net.esp32ncp] TRACE: NCP event 3
0000059842 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000059842 [system.nm] TRACE: Interface 4 power state changed: 3
0000059843 [net.esp32ncp] TRACE: NCP event 3
0000059843 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000059843 [system.nm] TRACE: Interface 4 power state changed: 1
0000059844 [hal] TRACE: Deinit modem serial.
0000059844 [net.esp32ncp] TRACE: NCP event 3
0000059844 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000059845 [system.nm] TRACE: Interface 4 power state changed: 3
0000059845 [net.esp32ncp] TRACE: NCP event 3
0000059846 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000059846 [system.nm] TRACE: Interface 4 power state changed: 1
0000059846 [hal] TRACE: NCP state changed: 0
0000059847 [net.esp32ncp] TRACE: NCP event 1
0000059847 [hal] TRACE: Deinit modem serial.
0000059947 [net.esp32ncp] TRACE: NCP event 3
0000059947 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000059948 [system.nm] TRACE: Interface 4 power state changed: 4
So, after cloud debug was installed via Chrome, again tried to flash the application & device OS from Workbench. It claimed success - but when coming back up, the cloud debug application was still loaded. Wasn’t paying attention to the LEDs after it went into DFU mode, so can’t say much of anything about that.
Hmm.
Oh for the love of pete’s pickled peppers… closing VSCode and opening it again resolved the issue. Able to flash without problems.
Note to future self: if anything seems to be behaving weird, just close the gdarned VSCode and start it up again before digging any deeper into it.
