Argon Error: Failed to initialize wifi NCP client: -210
Anyone ever seen this error before? Upon power up the module should be connecting to the local WIFI, it seems to try but then starts spitting this error out. This particular unit just came back from the field for an unrelated mechanical issue so I believe the radio was working properly prior.
Have you tried the Web Device Doctor ? I'd be interested in seeing the logs.
Sure, here's a screenshot of that.
