Where can I get the source code that is printing this message?
Is it some proprietary ESP32 Library?
I would like to figure out what -100 means on the code.
I did a search on the Particle Firmware repo on github and coudn’t find it.
Thank’s so hmm what would you recommend to solve this?
I am running on automatic mode shoudn’t the firmware in automatic mode handle the esp32ncpclient state so if it goes to disabled it will enable it again?
just to double check SYSTEM_ERROR_INVALID_STATE is -100? I coudn’t find a definition of it’s value in github.
Just a heads up, as per our release topic Gen 3 improvements update 2/2/19 an issue in regards to causing a deadlock for the NCP is addressed as per device issue #3. I highly suspect this is the issue you are experiencing and that this should be resolved in v0.9.0-rc2.
For now, I would sit tight until you’re able to try 0.9.0-rc2 and see if this issue persists post update.
Have it at a customer site at a remote location. Been trying to setup the stlink v2 with the Argon but I get some weird errors about cmsis-dap having the wrong parameters on eclipse.
I want to make sure it’s the same issue instead of waiting.
Based on the information provided and the info we are aware of at this time, I reasonably believe it to be the same thing. It would be best to use v0.9.0 as a base for further diagnostics before proceeding forward with further diagnosis.
I anticipate that it should be very soon, so the wait shouldn’t be too long.
