@Kahin, I have not tried it isolated on a breadboard with just a battery; if you think it will provide value, I can do so. But, I assume it will yield no better result than circuit that provides the 3.3v supply on the Crickit board.
Thank you for replicating my findings with the WiFi antenna. Perhaps this helps narrow down the issue.
This video shows connecting a LiPo battery to the GND and Li+ terminals, and the resulting reset loop that we’ve come to know and love. Then, I connect the same battery to the normal JST connector… and it works! Argon LiPo Battery Test
As far as I can tell with my DMM and the particle Datasheet, the JST positive connection and the Li+ connection are the same (and ground is ground). So, this makes no sense.
Special note: the trick where I power-on without the WiFi antenna connected, and then connect it… does not always work when running off this battery (it worked 2 out of 4 tries; when it didn’t work, it looked like it almost connected before going into the reset loop.
Blinking green with a short flash of white, repeat.
Plugging in a usb cord, with the Feather powered by 5V, allows the Argon to connect to the cloud and breathe cyan. I can then disconnect the USB cable and it remains connected for a while.
Having the same problem. Works great on USB, but will not power up on battery. Not a battery voltage or current issue. After having a problem and reading this thread, I tried using several batteries including a 5200mAh high output Lipo I use for a drone (this battery can output 50 amps). It’s also fully charged (4.2 volts). There’s something wrong.
I have several 2 Argons, 2 Photons, and have been using these in systems for a few years, so I’m not a total newb. I’ve got nothing connected to this Argon, just a battery connected to Li+ and Gnd.
My other Photon systems are in production so I can’t experiment with them. But, I know that my other Argon works on battery but it’s also running an older version of firmware. So, I’m going to try to downgrade the firmware on the Argon I’m having this problem with and see if that’s the issue.
It seems the Argon basically won’t function on a solderless breadboard. The slightest impedance and it won’t power up from the Li+ pin. I thought maybe it was the Lipo charging circuit, so I also tried SWD interface with the same results. Same issue with trying to power it via a NPN transistor (which is of course how we were planning on powering the device). Basically, this thing doesn’t function from a battery. It’s designed to be power ONLY via USB, with the battery as a backup (as long is it’s directly connected to the battery terminal).
I have a v1.0 Argon, maybe there’s been a hardware update that fixes this?
I believe the board is flaky (not sure if it’s all Argon boards or just this one). I tried to power it directly from the 3V3 pin via a 3.3v 800mA voltage regulator LM1117 (with decoupling capacitors and EN tied to GND) with the same results (3 green blinks and 1 white).
I have another Argon on the way as well as two Borons, this should isolate things.
It has been a long time ago, in the end support could not figure out the problem neither and they just sent a replacement. Sorry for not being able to help further
I have the exact same problem! As I also have three Xenons this is a pretty big problem with my current project. What’s the route to request a replacement? Any help much appreciated.
The last sale date for Xenons was April 30, 2020. The warranty doesn’t apply to deprecated devices, and would have long expired anyway. Once it was deprecated, all remaining units were sold and there is no stock of replacement Xenons. And even if you did find a replacement, there is no way to activate it, except for offline use.
