Argon and repeated/same/duplicate WiFi networks
I am using @Dan-Kouba 's web page to scan for networks around an Argon with his library.
I see what appears to be duplicate, in fact, triplicated, networks.
Is it normal for an Argon to detect the same Wi-Fi network more than once?
Is it a problem in the library or does the Argon really see duplicates?
If there are multiple access points with the same SSID, which is standard behavior for most larger networks, it will appear more than once on a scan.
When an Argon goes to connect, it will do a quick scan, then it will select the AP with the strongest RSSI that has a configured SSID.
