I’ve been working with APDS gesture sensors, primarily the Adafruit one, and I’m having trouble getting them to connect consistently. I’ll hook one up to a Photon or Argon using the code below and it will work fine. The next one that I hook up – nothing. The wiring, and the devices are the same. Is there a cache or something that I should be clearing, or something like that?
Thanks in advance!
#include <APDS_Trigger.h>
#include <SparkFun_APDS9960.h>
#include "APDS_Trigger.h"
//revision history
//040320 -- copied over from APDS-GESTURE-TEST.ino
//040720 -- added "DIR_NONE" to gestures.
//040920 -- removed "DIR_NONE" -- it was generated 4 events on startup, and then no more.
// location --> syntax = <LOCATION_CODE> Location IDs = CIC, TH
// keep one of these commented
#define LOCATION "CIC"
//#define LOCATION "TH"
// SEND_TO is LOCATION + BLOCK
#define SEND_TO "CICACTIONBLOCK"
//#define SEND_TO "THACTIONBLOCK"
// SEND_AS is LOCATION + BLOCK . This is for sending self-related info
#define SEND_AS "CICAPDSINFO"
//#define SEND_AS "THAPDSINFO"
const uint8_t gestures[] = {DIR_LEFT, DIR_RIGHT, DIR_UP, DIR_DOWN, DIR_NEAR, DIR_FAR};//removed DIR_NONE
class APDS : public APDS_Trigger
public:
APDS(){}
~APDS(){}
void performAction() override
Serial.print("Approved gesture\n");
Particle.publish(SEND_TO,"AUTO2",PRIVATE);
// Particle.publish(SEND_TO,"PRINT",PRIVATE);
// Particle.publish(SEND_TO,"DISPLAY",PRIVATE);
// Particle.publish(SEND_TO,"AUTO0",PRIVATE);
// Particle.publish(SEND_TO,"AUTO1",PRIVATE);
// Particle.publish(SEND_TO,"AUTO3",PRIVATE);
// Particle.publish(SEND_TO,"TONE",PRIVATE);
APDS apds;
Serial.begin(115200);
// while(!Serial.isConnected()) Particle.process();
Serial.println(apds.init(gestures, sizeof(gestures) / sizeof(uint8_t), true));
apds.update();
I wonder if the different chips are set for different default I2C addresses and only the ones where your calling the correct address work wile the others don’t?
Where are the sensors coming from?
I’ve seeing nothing abnormal with the ADPS sensor I have left running for days detecting distance & light levels.
Hi DC, nice to see you are still tinkering with Particle devices!
Since you mention that you have sensors from different vendors, perhaps @RWB is right and their default I2C address is not the same?
Have you tried by any chance the sample code DFrobot provides by any chance?
Cheers,
Gustavo.
PS: I just saw in the data sheet provided by dfrobot that the I2C address is always the same:
And, no, I wasn’t aware that DFrobot had sample code. Going to try that as well.
Do you think it makes sense to use the library from the same company as created the APDS9960 breakout board: in other words the Sparkfun library with the Sparkfun APDS9960 breakout board; Adafruit library with Adafruit APDS9960 board? Or doesn’t that really matter: it’s the same chip.
Oh and Armor, now I think I know what you meant by the code duplication: I’m using these in a few different locations around the Boston area. I don’t want them triggering each other.
I think I’ve resolved it! Someone at Cambridge Hackspace suggested double checking the supply and grounds. So I chucked the breadboard and directly connected the apds9960s to the Photons and Argons. And they all seem to be working fine now. That was surprising to me, because I thought that breadboards were generally reliable. And I could feel the jumper wires scratching the connective layer below. But now I’ll always be aware that they can introduce some variation.
Thanks everybody for the help!
On some breadboards the supply rails are not connected all the way through but may have a gap at the middle of the board (usually indicated by broken red/blue lines)
