Examples found use one feature of this sensor at a time. I'd like to use all of them simultaneously, just to test the timing, and eventually enable them in different moment to fit better my purpose, if timing doesn't.
According to datasheet, all the features can be enabled, they will be controlled by a state machine.
According to library, the setMode() is public and can be called by apds object.
I can't understand why i get this error when I attempt to set ADPS_ENABLE to ALL (0x7F)
../wiring/inc/spark_wiring_arduino_constants.h:28:21: return-state
ment with a value, in function returning 'void' [-fpermissive]
Then, why enableGestureSensor set ENABLE this way:
Gesture sensor is now running
apds.enableGestureSensor ENABLE REG:
1001111
Shouldn't be 1000001 ?
Shouldn't be 0x80<4-1> reserved to ALS sensor? And, as far as ALS concern, does this sensor need the bit 1 set to HIGH for Power On?
Thank you!
Thank you, ScruffR for you answer!
Thatās my whole code:
#include <Wire.h>
#include <SparkFun_APDS9960.h>
SparkFun_APDS9960 apds = SparkFun_APDS9960();
uint8_t proximity_data = 0;
// Initialize Serial port
// Initialize APDS-9960 (configure I2C and initial values)
if ( apds.init() ) {
Serial.println(F("APDS-9960 initialization complete"));
} else {
Serial.println(F("Something went wrong during APDS-9960 init!"));
Serial.println(F("apds.init() ENABLE REG:"));
uint8_t mode = apds.getMode();
Serial.println(mode, BIN);
// Start running the APDS-9960 proximity sensor (no interrupts)
if ( apds.enableProximitySensor(false) ) {
Serial.println(F("Proximity sensor is now running"));
} else {
Serial.println(F("Something went wrong during sensor init!"));
Serial.println(F("apds.enableProximitySensor(false) ENABLE REG:"));
// Start running the APDS-9960 light sensor (no interrupts)
if ( apds.enableLightSensor(false) ) {
Serial.println(F("Light sensor is now running"));
} else {
Serial.println(F("Something went wrong during light sensor init!"));
// Wait for initialization and calibration to finish
delay(500);
Serial.println(F("apds.enableLightSensor(false) ENABLE REG:"));
// Start running the APDS-9960 gesture sensor engine
if ( apds.enableGestureSensor(true) ) {
Serial.println(F("Gesture sensor is now running"));
} else {
Serial.println(F("Something went wrong during gesture sensor init!"));
//Trying to set all features
if( !apds.setMode(ALL, ON) ) {
return false;
Serial.println(F("setMode ALL ENABLE REG:"));
Iām just trying to control if I set set properly the REG.
But I canāt do manually (can I?) because the method is privete, so I need to call SetMode().
But when I attached //Trying to set all features code, i get that ERROR message on line 28. The same line that compile properly without the last portion of codeā¦
As I suspected, you are calling return false; in void setup() - this is not allowed. You can only call return; but not pass a return value when the function is explicitly declared not to return anything (void).
BTW, it's not code line 28 of your code, but of the file stated in the error message
This is where the fact that setup() is to be defined/implemented as void is first stated.
Iām sure you can do that manually since you can access the Wire object from user code without the use of the library, but why would you do that?
Libraries are meant to wrap complicated call sequences into more convenient - often single call - functions.
If you found an important feature not supported by a library itās usually best to file a issue on the GitHub repo and let the contributor add the missing feature.
Actually the Wire implementation is also written in C++, but modern C++ compilers produce very well optimised machine code, so the execution speed should be the least of your worries for this kind of setup.
You are extensively Serial.print()ing and have a delay(500) in there, so collecting nano seconds on the way doesnāt appear to be of much use IMO.
Yes, this short code is just for tests.
Iām trying to understand if itās possible to use this sensor in an efficient way without the state machine sequence.
I mean: iād like to use: proximity->color->gesture⦠because the gesture would be slow and detected on FALLING⦠so, if I want to print the color of the object that just passed along the sensor, would the normal sequence (prox->gesture->color) be good for this purpose? I donāt know yet, itās what i try to find out know
@Aloap If it helps attached code that does work with the sparkfun APDS-9960. I used the Particle library - Adafruit_APDS9960_Particle. It is pretty straight forward to understand. Using the define flags you can conditionally compile which sensor function required. BTW You have not set the interrupt pin with a PULLUP - that might be a reason it is not working.
This is a test for the APDS9960 digital proximity, ambient light, RGB, and gesture sensor
This sketch puts the sensor in proximity mode and enables the interrupt
to fire when proximity goes over a set value
These sensors use I2C to communicate. The device's I2C address is 0x39
// APDS9960 Photon
// VCC 3V3
// GND GND
// SDA SDA D0
// SCL SCL D1
// INT D2
#include "Adafruit_APDS9960_Particle.h"
// set only one flag true and rest false for that sensor mode
#define PROXIMITY false
#define GESTURE true
#define COLOUR false
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(MANUAL);
//the pin that the interrupt is attached to
int intPin = D2;
//create the APDS9960 object
Adafruit_APDS9960 apds;
while (!Serial.available()) delay(100);
pinMode(intPin, INPUT_PULLUP);
if (!apds.begin())
Serial.println("Failed to initialize device! Please check your wiring.");
else
Serial.println("Device initialized!");
#if GESTURE
apds.enableProximity(true); //enable proximity mode
Serial.println("Proximity Detection Set: True");
apds.enableGesture(true); //gesture mode will be entered once proximity mode senses something close
Serial.println("Gesture Detection Set: True");
#elif PROXIMITY
apds.setProximityInterruptThreshold(0, 120); //set the interrupt threshold to fire when proximity reading goes above 120
Serial.println("Proximity Threshold Set: True");
apds.enableProximityInterrupt(); //enable the proximity interrupt
#elif COLOUR
apds.enableColor(true); //enable color sensing mode
Serial.println("Colour Sensing Mode: True");
#endif
#if PROXIMITY
if (!digitalRead(intPin)) //print the proximity reading when the interrupt pin goes low
Serial.println(apds.readProximity());
apds.clearInterrupt(); //clear the interrupt
#elif GESTURE
uint8_t gesture = apds.readGesture(); //read a gesture from the device
if (gesture != 0)
Serial.print("Gesture Detected ");
if (gesture == APDS9960_DOWN) Serial.println("v");
if (gesture == APDS9960_UP) Serial.println("^");
if (gesture == APDS9960_LEFT) Serial.println("<");
if (gesture == APDS9960_RIGHT) Serial.println(">");
delay(200);
#elif COLOUR
//create some variables to store the color data in
uint16_t r, g, b, c;
//wait for color data to be ready
while(!apds.colorDataReady())
delay(5);
//get the data and print the different channels
apds.getColorData(&r, &g, &b, &c);
Serial.print("red: ");
Serial.print(r);
Serial.print(" green: ");
Serial.print(g);
Serial.print(" blue: ");
Serial.print(b);
Serial.print(" clear: ");
Serial.println(c);
Serial.println();
delay(500);
#endif
armor , could I ask you some explanations about your code?
You define: SYSTEM_THREAD(ENABLED);
in which part of the code a different thread is used? Is the loop continuing even during delay()?
Is Thread effective in AUTOMATIC MODE?
I cannot test your code because of it blocks somehow the Photon but Iām trying to integrate it in my previous code and with the library Iāve been using. I tryied the pullup advice, and it seems to work for the first readings of data, but after three/four readings, the loop stops to provide data (but even in the previous loops my gesture sensor never worked properly).
I guess I havenāt understand much the behaviour of this sensor⦠any help is welcome!
Thank you.
I cannot make armor code workingā¦
ScruffR, Iāve been reading that part but Iām not sure I can understand well the functionalities.
Setup() apart, what other functions of the code are involved in threading?
Iāll try to get a better look to the documentationā¦
@Aloap If it is working somewhat then you are making progress!
I bought the sparkfun board first ($12) and then spotted a copy on Aliexpress for $2. Both work for me but you need to be careful with pullup resistors on the SDA and SCL lines to 3V3 (not required with sparkfun board) and also the Vcc - sparkfun is 3V3 whereas the cheap copy is 5V as it has voltage regulator on board. Lastly, there are soldered jumper selection on the sparkfun board - make sure the board is connected correctly. Try referring to the sparkfun datasheet.
The SYSTEM_THREAD(ENABLED) and SYSTEM_MODE(MANUAL) are only there because I always use system threading and for this test a WiFi/Cloud connection is not needed with output to serial port.
Personally, I found that the sensing distance to be much less than the 20-25cm indicated and more like 10cm. Also, the sensor is affected by the lighting conditions when using gesture control and was not as reliable as I was looking for. Good luck.
@armor, yes, the sensor works properly if I use it just one feature at a time. I cannot use it the way Iād like⦠because I would like to do a proximity stop, a color measuring and a gesture detection, all in the same firmware and in the same time (except for delay the sensor need).
In this case, gesture never works and loop stops after some measurings I donāt know whyā¦
No problem for voltage, Iām using the sensor with Photon board.
I agree with you both about proximity efficienty and light sensing: the first is not accurate over 10 cm and even when the target is really near. After some point it always read 255.
The lighting read greys if it is not in optimal light condition. So, itās pretty unusefull in most cases.
Gesture seems to work good. But I need to detect the color and the direction of something that passes through the sensor and it seems to be impossible with only one sensor like that. I donāt know if itās my fault because I cannot program it in the right wayā¦
I would suggest reading the specification sheet for the APDS-9960. I think you will find it can do proximity trigger and gesture but not distance measurement and gesture and colour at the same time or if it can, the driver software canāt handle that. I thought this sensor might provide ācheapā gesture control but it appears to be too limited. I have used a Flick board with Raspberry Pi - these are really good for hand gesture - they use electric field detection but are too expensive for my application.
I see, thank you for your advice! IāƬ guess I have to sacrifice gesture, and read just distance and color. Or maybe use two of this sensors, once for proximity and the other for gesture, using the pin interrupt of the proximity one to power on the second
