I read the docs and searched the forum - promise!
Has anyone had experience with this? It seems I could use a 12V panel on Vin or a 6V panel with a USB converter on the USB-C port. The normal behavior of the tracker is to wake when the USB-C port is connected. Anyone try using the tracker with solar and a low-power use case?
Thanks, Chip
