[Answer]-Flash program without Wifi Connection
Hey Guys,
Hope you are having a good day,
I am currently on a locked-down network, and cannot connect to the Particle Cloud. Therefore, I am trying to debug my connection issues, one of the methods of checking the network side is using a MAC Address. I know I can make a simple program to find a MAC Address but I cannot push that program to the Photon without a wifi connection.
If possible, I am trying to flash this program without Wifi, any suggestions?
Thank you,
Sam
Yes, via USB in DFU Mode
particle flash --usb <yourFirmwareFile.bin>
or in Listening Mode (less reliable)
particle flash --serial <yourFirmwareFile.bin>
(corrected, thanks @shiv for the heads up)
Great! Thank you, I have managed to flash it manually! Learning more each day.
Thank you,
Sam Herring
That's a new one. I've seen --Serial but not text. So what's the difference @ScruffR?
Considering I haven’t seen it either, let’s call it a typo. That should be --serial :wink:
Yup, was I typo. I meant to put it in a
 ```text
 block
so the `text` sneaked in twice :blush:
