[SOLVED] Setup over usb on computer without WiFi
Solution: Have a look at particle serial wifi.
Hi Everyone,
Is it possible to setup a particle using USB and the CLI only? i.e. from a remote computer that does not have WiFi?
My senario is to remotely setup a brand new particle that is connected via usb to a remote desktop computer that does not have wifi. Is this possible?
Andy
Yes.
There are numerous topics about this, as well as it being documented, so explaining the process is mèh… Have a look at particle serial wifi.
It seems to have its own page in the docs: https://docs.particle.io/guide/getting-started/connect/photon/
Great, thankyou
This doesn’t completely solve the setup though (unless I’m mistaken). It won’t register the device with the cloud. I have an open issue on the CLI for that - https://github.com/spark/particle-cli/issues/315
My issue covers the serial setup but my Windows 10 connection over WiFi to the photon is super flaky so I would love to just do the setup that way.
Once the device is online, simply issue particle device add [ID], or doesn’t that help either?
Yeah, that totally works but the normal setup flow calls the Create A Claim Code flow. I’m trying to test the calls that get made in that flow.
I guess it really doesn’t make sense to call that over serial since I think it’s more for SoftAP?
