Angled usb c cable
I bought this setup an dhav ejust discovered that I only have one algled USB c cables (the one that attach to the board, and then connects to power supply etc more eaasily when using th eenclosure.
Can i have a link for the cable pelase ..ty
Unfortunately the USB cable can't be purchased separately from Particle and the link I had to a compatible one from Amazon is no longer available. However, "short right angle usb c" does return a bunch of results that look similar. Other search terms that may be helpful include "40Gbps" and "laptop."
thanks for replying.
I did get one when i originally purchased particle along with the m1 enclosure.
You would assume that Particle might have access to parts for their own product, but perhaps thats to much these days to expect!
appreciate the advise
The reason you can't buy most of the components of the kits separately is that a manufacturing company manages the assembly of the kits, so we don't have a pile of cables in a back room of our office. Likewise, we don't send out the packages; they're sent from the manufacturer to the shipper, who grabs the SKU off their shelf and puts it in a box and mails it. It costs money to keep each separate SKU on their shelves, so we don't break down each SKU into its dozen components because the individual pieces would have such low volumes as to not be cost-effective. If you've ever bought some random consumer product and some small part of it failed and they shipped you an entire brand new packaged unit, it's probably for the same reason.
ahhh i see. That's make's more sense now. Appreciate your response!
