Android LED controling app
is there an android app through i can control my LEDs? I use WS2812B LED strip and Photon.
Hey @HexaGT, thanks for posting!
You have a couple of options here:
  1. Use the built-in Tinker app (https://build.particle.io/examples/56214d636666d9ece3000006) and control the GPIOs using the Particle Mobile App. This is pretty easy with simple LEDs, but likely not possible with W22812Bs
  2. Build a quick and dirty mobile app using a tool like NativeScript and the Particle NativeScript Plugin. I wrote a blog post on this a while back that might help you get started. @jaredwolff also wrote a comprehensive post in January that’s worth checking out.
Good luck and let me know if you need any additional help!
Brandon
Another option would be to use Blynk.
Here’s their getting started page:
Good luck!
