Airtable Documentation and Examples
Hey Particle Community!
I'm hoping to create a simple integration to Airtable to update a string and number field. It seems like there is an integration partner with Airtable but when trying to access the setup documents it redirects to a generic Airtable help page.
Is there documentation out there in the particle space that shows an example of updating Airtable and a setup guide to accompany it?
Thank you in advance!
I'm not aware of any documentation for Airtable. However it appears to have a standard REST API, which you should be able to access using webhooks and a personal access token. This is basically the same as how you'd access any web service, so it should be possible.
