So I found someone else who got stuck at "flashing cyan and blue", here:
I followed the instructions. Downloaded the Particle CLI installer, it installed flawlessly. Or so I thought, apparently it didn't install an OpenSSL, I had to go find one manually, then manually move it to the system32 folder.
But I did that. And then I was finally able to run the command:
C:\Windows\system32>particle keys doctor 21003a000151343530343432
Found DFU device 2b04:d006
New Key Created!
I couldn't find the file: 21003a000151343530343432_rsa_new.der
Make sure your device is in DFU mode (blinking yellow), and that your computer i
s online.
Error - I couldn't find the file: 21003a000151343530343432_rsa_new.der
I have no idea what any of this means, it says new key created, but then it can't find the key it just created?!
