Adafruit VEML7700 Library Support
Hello,
I would like to know if anyone is using the VEML770 Lux sensor breadboard from Adafruit. The board is pretty recent this might the reason why it is not available yet, but I was wondering if someone was working on it ? I’d like to use the board but I’m not skilled enough to convert the Arduino Library to Particle.
Cheers :smiley:
I keep seeing more and more Adafruit libraries using the Adafruit_I2CDevice and Adafruit_I2CRegister “libraries”. Once these may get ported to Particle (if the aren’t already) then the VEML770 library should need no further porting (AFAICT).
Yeah Adafruit_I2CDevice is the one thing blocking me in the transfer…
did you get this working?
No. Could anyone make this libraries available ?
Does this help?
Works perfectly !
Thanks :slight_smile:
