When I try to compile using monitor edge in workbench, I get an access token provided is invalid compile error. However, I’m not sure where to put in my access token?
Use the Particle: Login command in the command palette (Ctrl-Shift-P or Command-Shift-P).
You could also use the particle login command from the Partcile CLI.
This worked thank you.
