I've been trying to get Particle Workbench working so I can compile Tracker-Edge to add the humidity sensor capability. I'm running Windows 11 with VS Code and have followed the documents to install the Workbench and components and they all appear to have installed fine, however I cannot login for the cloud functions.
I have tried numerous times and I copy and paste my username, password, and 2FA from my password manager. I know those work to login at console.particle.io just fine.
In the output I get:
Error: Command failed with exit code 1: c:\Users\XXXXX\.vscode\extensions\particle.particle-vscode-core-1.16.13\src\cli\bin\windows\amd64\particle.exe login [LOGIN DETAILS REDACTED]
Cannot find module './copy-sync'
I've done a lot of searching and can't find a fix for that. I've uninstalled and reinstalled the extensions with no luck. Has anyone had this issue and knows a way to resolve it?
