Hi there,
I bought 10 cores with the Kickstarter campaign and am just getting to playing with them. I dusted them off today (figuratively) and successfully updated all to v0.3.4 with DFU_Util. Nine of the cores are talking to my online account, no problem.
But one just won’t get past blinking green. I tried:
- reflashing the v0.3.4 firmware + factory reset + reset (which worked for all others)
- patching the cc3000-patch-programmer.bin per this page:
https://github.com/spark/cc3000-patch-programmer
(after flashing and dark LED, holding MODE for >1sec didn’t do anything.)
- gave up and reflashed v0.3.4 to recover
Not sure what else I can do. Any thoughts?
Thanks, in advance.
Michael
What happens when you perform a factory reset?
Solid blue? Or blinking blue?
Anyways, sounds like you are using DFU-util so try flashing this CC3000 binary: https://github.com/spark/particle-cli/blob/master/binaries/cc3000-patch-programmer.bin
Oh yes.
- Tinker app - connect a core, etc.
- blinking blue
- solid blue
- blinking green…
I tried the CC3000 flash. The LED goes dark but any attempt to hold down the MODE button for >1sec does nothing. LED remains dark. No flashing magenta. Holding MODE long enough returns to flashing yellow mode.
M
Sounds like the CC3000 patch isn’t running…
Maybe a replacement is easier?
I’m thinking a replacement may be needed. I’ve exhausted all the recovery options I could find in the particle.io site.
Whom do I reach out to for a swap?
Michael
