This is the error that breaks the build
And here is the culprit
The function signature promises to return a bool but the function never does.
@Colleen, could you please also take on this library to get repaired?
As it appears there is no contributor's repo to file an issue.
library.properties only provides a link to the original Adafruit repo where this issue was already taken care of but never made it into the Particle libraries repository.
