I am working on a project in which I am trying to connect an Electron microcontroller to a external GPS unit. The GPS I am using is the Adafruit GPS Antenna - External Active Antenna. I am using the 1_GPS_Features.ino example code from the AssetTracker library provided by Particle. However, when I have tried to compile the example 1_GPS_Features code provided by Particle, I have received the following error message:
lib/Adafruit_LIS3DH/Adafruit_LIS3DH.cpp:320:1: no return statement in function returning non-void [-Werror=return-type]
AssetTracker.h includes the Adafruit_LIS3DH.h file. I did not write that code nor did I make any adjustments to the 1_GPS_Features.ino example so I am not sure how to go about addressing this error without having to edit the Adafruit_LIS3DH.h code. I would appreciate any assistance with this issue.
