Zigbee and Particle devices
Hi, I'm curious to know if any of you have played with any interaction of Zigbee sensors and Particle devices, by connecting a Zigbee capable chip to a Particle device.
Edit: I've seen this post (Xbee modules could speak zigbee I believe):
What I'm interested today is in finding out if I can interact with a zigbee sensor, example:
You can't use a Particle device with Zigbee directly; you'd need to add a secondary MCU for that. While the nRF52840 can support Zigbee, it uses a different SoftDevice binary and would not fit. Remember when Gen 3 user binaries expanded from 128K to 256K in 3.2.0? That was possible because we took the space used by the large SoftDevice for Particle Mesh (6LoWPAN over 802.15.4) and used it for the user binary instead. The Zigbee SoftDevice is similarly large.
Yes, sorry I wasn't clear on this. I meant to ask if anybody added an extra MCU that allowed them to connect to Zigbee devices and how did it go.
I never meant (and I did not know there was a chance in the past) to connect directly.
Thanks for the inside story!
