Xenon flashes CHG light briefly when plugged in but then displays no signs of life. Status LED doesn’t come on. Holding down the mode and reset buttons causes the CHG light to flash yellow but only intermittently. Is there a fix for this?
Xenon won't turn on
armor
#4
Was this a noob Xenon? It might be it is faulty - when plugged into to microUSB can you get it into DFU mode? It that works then I suggest you flash via USB System part1, tinker and bootloader (serial) that might recover it. If it is faulty then log with Particle support.
kpoulter
#5
Cannot get it into any mode at present. The status LED is off and button presses are having no effect
