Xenon Went dark on Me
I am having a problem …My Xenon went into a hard fault and the only way to recover it was to USE it in DFU mode flashing yellow then I flashed tinker-0.9.0-xenon.bin and it says flash success then the device goes dark and the only way to see it is to put it in DFU Mode any ideas ??
Hi @jade7272,
Can I ask you to do the following?
In CLI, run the following semi-magic commands:
particle update
and
particle flash --usb tinker
Let me know if this does not bring it back to a known state.
Actually that worked thank you
