Greetings. I see Xenon has handlers for DSP/Audio. I’ve also seen a few conversations about audio streaming to Particle.
My question is confined to a locally defined mesh: Xenon to Boron/Argon to Xenon via UDP; I would presume then that Xenon to Xenon is supported.
My use case is using Xenons, in part, as a full-duplex audio gateway in addition to IMU data (to the cloud). The Boron/Argon may serve audio files (playlist) or act as a mux for other UDP endpoints. No heavy weight traffic to the cloud; just telemetry. The audio would be a live stream with capture feature options for portions. Local storage.
Am I barking up a good tree?
