How do I update the available OS under Target > Configure for device ?
Currently I am at 1.4.1-rc.1 and would like to use 1.4.4.
I normally click here on the OS version and it prompts you for which one you want. If not available it automatically downloads what it needs.
The one I want is not showing
Is there an update pending
- click on the cog and then Check for Updates… in the menu.
have you done a particle update-cli from the command line recently ?
Thanks all After an dependency update and restart it is updated.
for posterity, here’s how to update an extension:
