Hello,
I started working with Workbench.
But it won’t compile my code.
The code compiles in the cloud.
Can someone see something from the error message?
thanks
In file included from ./inc/Arduino.h:26,
from /Users/vr/Documents/TomatoTent//src/tent.h:5,
from /Users/vr/Documents/TomatoTent//src/api_server.cpp:6:
/Users/vr/Documents/TomatoTent/lib/ArduinoJson/src/ArduinoJson/Polyfills/pgmspace_generic.hpp: In instantiation of 'typename ArduinoJson6194_F1::enable_if<ArduinoJson6194_F1::is_pointer<T>::value, T>::type ArduinoJson6194_F1::pgm_read(const void*) [with T = const __FlashStringHelper*; typename ArduinoJson6194_F1::enable_if<ArduinoJson6194_F1::is_pointer<T>::value, T>::type = const __FlashStringHelper*]':
/Users/vr/Documents/TomatoTent/lib/ArduinoJson/src/ArduinoJson/Deserialization/DeserializationError.hpp:85:12: required from here
../wiring/inc/avr/pgmspace.h:148:29: error: 'const void*' is not a pointer-to-object type
148 | #define pgm_read_ptr(addr) (*(const void *)(addr))
make[3]: *** [../build/target/user/platform-8-m/TomatoTent/src/api_server.o] Error 1
make[2]: *** [user] Error 2
make[1]: *** [/Users/vr/.particle/toolchains/deviceOS/3.3.0/modules/photon/user-part/makefile] Error 2
make: *** [compile-all] Error 2
The terminal process "/bin/bash '-c', 'make -f '/Users/vr/.particle/toolchains/buildscripts/1.10.0/Makefile' compile-all -s'" terminated with exit code: 2.
Press any key to close the terminal.
