I can compile the following source code successfully on https://build.particle.io, but the compilation fails in the Particle Workbench with “Cloud Compile”.
Source code:
SYSTEM_MODE(AUTOMATIC);
SYSTEM_THREAD(ENABLED);
waitUntil(Mesh.ready());
Mesh.subscribe("temperature", myHandler);
Mesh.subscribe("pressure", myHandler);
void myHandler(const char *event, const char *data) // char * means a pointer to a charcter string with the ending of "\0"
Particle.publish(event, data, PRIVATE );
Compilation logs:
Compiling code for argon
Targeting version: 0.8.0-rc.25
Including:
src/argon_subscribeAndPublish.ino
src/argon_subscribeAndPublish.cpp
project.properties
Processing src/argon_subscribeAndPublish.ino
make -C ../modules/argon/user-part all
make[1]: Entering directory '/firmware/modules/argon/user-part'
make -f ../../../modules/shared/nRF52840/build_linker_script.mk PREBUILD=1
make[2]: Entering directory '/firmware/modules/argon/user-part'
Creating module_user_memory.ld ...
make[2]: Leaving directory '/firmware/modules/argon/user-part'
make -C ../../../user
make[2]: Entering directory '/firmware/user'
Building cpp file: src/argon_subscribeAndPublish.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-12-msrc/
arm-none-eabi-gcc -DSTM32_DEVICE -DnRF52840 -DNRF52840_XXAA -DPLATFORM_THREADING=1 -DPLATFORM_ID=12 -DPLATFORM_NAME=argon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD00C -DUSBD_PID_CDC=0xC00C -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DINCLUDE_PLATFORM=1 -DSOFTDEVICE_PRESENT=1 -DS140 -DPRODUCT_ID=12 -DPRODUCT_FIRMWARE_VERSION=65535 -DOPENTHREAD_PROJECT_CORE_CONFIG_FILE=\"openthread-config-project.h\" -DENABLE_FEM=1 -DNRF_802154_PROJECT_CONFIG=\"openthread-platform-config.h\" -DRAAL_SOFTDEVICE=1 -D_WIZCHIP_=W5500 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DLFS_CONFIG=lfs_config.h -DSYSTEM_VERSION_STRING=0.8.0-rc.25 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/src -I../hal/inc -I../hal/shared -I../hal/src/argon -I../hal/network/lwip/esp32 -I../hal/src/nRF52840 -I../hal/src/armv7 -I../hal/src/nRF52840 -I../hal/src/nRF52840/lwip -I../hal/src/nRF52840/freertos -I../hal/src/nRF52840/openthread -I../hal/src/nRF52840/mbedtls -I../hal/src/nRF52840/littlefs -I../hal/network/api -I../hal/network/lwip -I../hal/network/lwip/posix -I../hal/network/openthread -I../hal/network/lwip/wiznet -I../hal/network/ncp -I../hal/network/ncp/at_parser -I../third_party/lwip/lwip/src/include -I../third_party/freertos/freertos/FreeRTOS/Source/include -I../third_party/nrf5_sdk/nrf5_sdk/external/freertos/portable/GCC/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/external/freertos/portable/CMSIS/nrf52 -I../third_party/openthread/openthread/include -I../third_party/openthread/openthread/src/core -I../third_party/openthread/openthread/examples/platforms -I../third_party/openthread/openthread/third_party/NordicSemiconductor/drivers/radio -I../third_party/openthread/openthread/third_party/NordicSemiconductor/drivers/radio/hal -I../third_party/openthread/openthread/third_party/NordicSemiconductor/drivers/radio/raal -I../third_party/openthread/openthread/third_party/NordicSemiconductor/drivers/radio/raal/softdevice -I../third_party/wiznet_driver/wiznet_driver/Ethernet -I../gsm0710muxer/gsm0710muxer/include -I../platform/shared/inc -I../third_party/nrf5_sdk -I../third_party/nrf5_sdk/nrf5_sdk/components/toolchain/cmsis/include -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers/include -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/hal -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/mdk -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/hal -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers/src/prs -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/util -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/common -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fstorage -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_section_vars -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/crc32 -I../third_party/nrf5_sdk/nrf5_sdk/components/drivers_nrf/usbd -I../third_party/nrf5_sdk/nrf5_sdk/integration/nrfx/legacy -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/delay -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_log -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_log -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_log/src -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_section_vars -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/delay -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/queue -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/common -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/mbr/nrf52840/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140 -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fifo -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic_fifo -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/strerror -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fstorage -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic_flags -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd/class/cdc -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd/class/cdc/acm -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/common -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/nrf_ble_gatt -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/ble_advertising -I../third_party/nrf5_sdk/nrf5_sdk/external/nrf_cc310/include -I../third_party/littlefs/littlefs -I../platform/MCU/nRF52840/inc -I../dynalib/inc -Isrc -I./libraries -I. -MD -MP -MF ../build/target/user/platform-12-msrc/argon_subscribeAndPublish.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=ESP32 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0xD4000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=5 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,1,324 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\"" -fno-exceptions -fno-rtti -fcheck-new -std=gnu++11 -c -o ../build/target/user/platform-12-msrc/argon_subscribeAndPublish.o src/argon_subscribeAndPublish.cpp
In file included from ../wiring/inc/spark_wiring.h:50:0,
from ./inc/application.h:40,
from src/argon_subscribeAndPublish.cpp:1:
src/argon_subscribeAndPublish.ino: In lambda function:
../wiring/inc/spark_wiring_system.h:458:74: error: expression cannot be used as a function
#define waitUntil(condition) System.waitCondition([]{ return (condition)(); })
src/argon_subscribeAndPublish.ino:5:3: note: in expansion of macro 'waitUntil'
../wiring/inc/spark_wiring_system.h: In instantiation of 'static bool SystemClass::waitConditionWhile(Condition, While) [with Condition = setup()::<lambda()>; While = SystemClass::waitCondition(Condition) [with Condition = setup()::<lambda()>]::<lambda()>]':
../wiring/inc/spark_wiring_system.h:251:34: required from 'static bool SystemClass::waitCondition(Condition) [with Condition = setup()::<lambda()>]'
src/argon_subscribeAndPublish.ino:5:3: required from here
../wiring/inc/spark_wiring_system.h:244:39: error: could not convert '_condition.setup()::<lambda()>()' from 'void' to 'bool'
while (_while() && !_condition()) {
../wiring/inc/spark_wiring_system.h:244:28: error: in argument to unary !
../wiring/inc/spark_wiring_system.h:247:27: error: void value not ignored as it ought to be
return _condition();
../build/module.mk:277: reci
Error: Command failed: /Users/john/.vscode/extensions/particle.particle-vscode-core-1.0.0-alpha.5/src/cli/bin/darwin/amd64/particle cloud compile argon --target 0.8.0-rc.25
Including:
project.properties
at makeError (/Users/john/.vscode/extensions/particle.particle-vscode-core-1.0.0-alpha.5/node_modules/execa/index.js:174:9)
at module.exports.Promise.all.then.arr (/Users/john/.vscode/extensions/particle.particle-vscode-core-1.0.0-alpha.5/node_modules/execa/index.js:278:16)
at <anonymous>
