Workbench - Creating New Project Fails [Solved]
Hi!
I tried to create a new Project in Workbench and it kept failing with the following error:
particle: Adding dependencies...
 ▸    Get https://binaries.particle.io/node/v5.4.1/node-v5.4.1-darwin-x64.tar.gz: dial tcp: lookup binaries.particle.io on 192.168.0.5:53: write udp 192.168.0.187:58046->192.168.0.5:53: write: host is down
 done
particle: Installing plugins...
 ▸    fork/exec bin/node: no such file or directory
particle: Installing plugins (retrying)...
 ▸    Error installing package.
 ▸    Try running again with GODE_DEBUG=info to see more output.
What actually solved it for me that I turned off my firewall (LittleSnitch) which prevented incoming (? :open_mouth: ) connections. Now, with an updated rule for “particle.io” it works!
Thank you for putting your solution!
