@futurebird,
the access token for the Web IDE and Spark-cli are using 2 different ones. What’s your convern about this?
I don’t have to use sudo on my mac for Spark-cli. How did you install it?
I had to use sudo for the install too.
Yup that’s needed as you need to install the npm module globally using sudo npm install -g spark-cli
After that, the command should work simply using spark xxx
Seem to have solved my problem although I still don’t understand why this was happening. I ran
sudo chown myname /Users/myname/.spark/spark.config.json
and now everything is working fine. I wonder how the permissions got messed up? Thanks for the clarification about the tokens. By the way, if I want to check on a variable using terminal do I need to use the Spark.variable command? Right now “spark get” says my core has not variables. (but it’s sending data so It must…)
Yes spark list will show the functions and variables you declared in your user firmware.
If you did not use it, there’s nothing registered with the
so it’s empty.
Have fun!!
