Trying to learn webhooks this afternoon and proceeded by installing node.js and following Kenneth’s instructions.
After typing in the command sudo npm install -g spark-cli I get the following message. I cannot type any characters in after the Password.
Please help me get passed this hurdle.
bens-MacBook-Air:~ bentoskey$ sudo npm install -g spark-cli
WARNING: Improper use of the sudo command could lead to data loss
or the deletion of important system files. Please double-check your
typing when using sudo. Type "man sudo" for more information.
To proceed, enter your password, or type Ctrl-C to abort.
Password:
are you sure you cannot enter your password? I think you can type just you cant see it(like linux). so type in your password and hit enter if it says error try again but make sure you entered the correct password. let me know how it goes!
@BenToskey if librato.json is premade and you are calling it maybe it’s asking for a command after you call it like spark webhook create librato.json command
Or maybe it’s asking for an event you want to add you want to the file.
Sorry I’m not that good at spark cli I just knew about the password thing sorry
The CLI is telling you either that it can’t find the librato.json file in the same directory as you. If you’re on a mac, you can type open . and it’ll open a finder window in your current folder and you can place the file there.
bens-MacBook-Air:~ bentoskey$ spark webhook create librato.json
tryParse error [SyntaxError: Unexpected token “]
Using settings from the file librato.json
Please specify an event name
It looks like the editor you used put in “Smart Quotes”:
"username": “user.me@gmail.com”,
Notice how the quotes around “username” differ from the quotes around your username? Make sure you remove all those special quotes and then it should work.
