Cant seem to install spark-cli - Loggin in as admin using sudo -s [Solved]
Hi, my spark core needs to be claimed. I’m having a lot of difficulty installing the spark-cli using the commands provided.
I tried sudo, I tried sudo -s, please see the attached screenshot.
Has it got anything to do with the LED ‘breathing’ magenta?
Vish
You shouldn't have to be root to use npm on a single user osx machine - try the following:
$ whoami
[your-username]
$ sudo chown -R [your-username] /usr/local
$ sudo chown -R [your-username] ~
The last two commands reclaim your user access rights for non-system related installed files and for all files/dirs in your own home directory.
From there on npm, brew and so on won't need root permissions via sudo anymore, so even a
$ npm install -g spark-cli
should smoothly work!
Its a pure software issue without any connection to the Spark Core itself.
Good luck :wink:
Thank you for your prompt response. I tried the suggested changes, this is what I’m seeing now:
Could you make another screenshot/copy of the information some lines up?
Sure, it’s broken down into two screenshots:
Execute
$ sudo xcodebuild -license
and try again :sunflower:
Thank you, I did it and it said something about me not agreeing to the Xcode license, I had assumed that message wasn’t related, but I went into the Xcode GUI and agreed to the terms and now the Spark CLI works just fine.
Thank you very much for your support!
Vish
