Stuck installing spark-cli any pointers would be great
I haven’t done anything with my cores for a while and as I have 2 weeks off work I decided to work on a project thats been in my mind for ages.
In order to get debugging I’m trying to get data sent out to the serial monitor, however I can’t see any new serial devices when I plug a core in like before, even with the new Spark Dev app.
Reading through some posts it looked like I need to install spark-cli to get it working, would I be correct in thinking that?
Anyway, Node.js installed fine.
$ npm install -g spark-cli
^ this did not appear to work as it was giving lots of errors, warnings, etc, so reading on more forum posts it suggested trying without the -g flag. Output from that seemed to do the trick.
Ok, next:
$ spark cloud login
Resulted in
-bash: cloud: command not found
So tried to update my .bash_profile. I think this is where I’m stuck.
What files should be in the directory that the path is pointing to?? I took a look at:
/Users/cjnewbs/.npm/spark-cli
and there was one folder, “1.0.0”, in that was “package”, inside that was “package.tgz”, and a folder “package” containing “package.json”.
I extracted the package file, into the “package” folder and updated the “.bash_path” file to point to it.
Am I even going in the right direction?
Any help is much appreciated.
@cjnewbs,
you will need Serial.begin(xxxxxxxx) in your setup() for the firmware you use in order to see a serial device. Spark-cli is not required. :slight_smile:
Use sudo npm install -g spark-cli --verbose
To login, try spark login
Thanks for your help,
spark-cli install did a whole bunch of stuff it wasn’t doing before during the install, so it looks like it went ok, strangely “spark” command still not found, I’ll take a look a that later though.
It looks like it wasn’t showing up in the serial monitor as Spark Dev wasn’t flashing the firmware.
Now I’m back on track, thanks again.
