I’m using a Boron and need to connect an external device (accelerometer) that is supposed to be able to wake-up the nRF5 (once Device OS supports sleep modes) using a rising edge on a GPIO pin. Which pin should I connect this to? I’m new to the nRF5, but it looks to me like any GPIO input can be used for this purpose, is that correct?
For stop mode sleep you can use any pin since you specify the pin in the call.
Since the API for SLEEP_MODE_DEEP does not include a pin number and mesh devices don’t have a WKP pin, pin D8 will be used as WKP for SLEEP_MODE_DEEP (once implemented).
