Where can I find the source to the bootloader and copy of the released bin file?
Happy New Year! We just open sourced it.
@zachary Is there any way to get the Core into bootloader mode without using the Mode button? I’m trying to setup a Raspberry Pi as a little “local build & flash” server. I’d love to make a shield that I could drop the Spark Core into and then just let the Raspberry Pi pull the reset pin and get it into DFU mode without me having to touch it!
If it comes down to it, I suppose I can just modify the bootloader to allow it somehow…
Nope, no other way without modifying the bootloader.
Okay, maybe I’ll modify it to listen on serial for 3 seconds before continuing a normal boot. I also saw something about a JTAG shield for the Raspberry Pi, so I might look into that as well.
