Webhook woes :)
Hi -
@Support
Hoping someone can point out what I am doing wrong. I am setting up a new webhook to send data to @Blynk. I have done this before, several times in fact but for some reason something is amiss this time.
First check, yes... I have the Blynk-stuff right at the top of my firmware. For the sake of clarity, I am leaving my auth token exposed, will change it later.
#define BLYNK_TEMPLATE_ID "TMPL4doYO7xzH"
#define BLYNK_TEMPLATE_NAME "Smart Pot"
#define BLYNK_AUTH_TOKEN "Nmjfq45ZMWASwdD6IXEQMx1x0xj4hYvC"
const char *WEBHOOK_NAME = "Blynk_Send";          // Particle Webhook name
This is where I actually construct and send the message:
void publish () {
    snprintf(data, sizeof(data)
        , "{\"t\":\"%s\",\"sun_light_level\":%i\"soil_level\":%i}"
        , BLYNK_AUTH_TOKEN, sun_light_level,soil_level
        Particle.publish("Send_smartpot_data", data, PRIVATE);
This is the message I get from Particle events:
{"t":"Nmjfq45ZMWASwdD6IXEQMx1x0xj4hYvC","sun_light_level":0"soil_level":0}
Now comes the problem. The webhook keeps failing with the the following response.
HTTP/1.1 400 Bad Request
connection: keep-alive
content-type: application/json;charset=utf-8
access-control-allow-origin: *
content-length: 42
{"error":{"message":"No token provided."}}
Digging deeper I noticed the following.
EVENT:
content-length: 42
REQUEST:
GET /external/api/batch/update?token=&V0=&V1= HTTP/1.1
User-Agent: ParticleBot/1.1 (https://docs.particle.io/webhooks)
host: fra1.blynk.cloud
Connection: keep-alive
For the life of me, I do not know why the Auth token is not passed.
I really hope I am missing something very obvious.... :exploding_head: :smile:
Regards,
Friedl.
There's a typo here:
                                     ^here
There needs to be a comma between the i and \. Since the JSON payload is invalid it can't be parsed so all of the template variables will be empty.
@rickkas7
OH MY WORD!!! :exploding_head: :blush:
Thanks, really appreciated, I was going insane! Let me check quick.
You are a lifesaver, thanks @rickkas7 :smiling_face:
Friedl,
You can use a json validator online like:
Or any other.
I copy pasted your json and it gave the error away :slight_smile:
Best
Hi @gusgonnet -
Thank you for your patience, soooo many new things for me but I am trying to learn as I go along.. :exploding_head:
Appreciate the info on the validation tool, will most certainly make use of it! Good to have all these tools to help out when stuck.
Regards.
Friedl.
