Any plans to increase the 255 byte limit on the data argument of the Particle.publish() method? I’m reaching the limit primarily due to the length of the access token (~230 bytes) I need in order to authenticate with the end server, and also because I want to limit the use of the WiFi to conserve battery so I’m sending all data (~40 bytes) in one request.
I’m referring in particular to the custom template variables data argument.
Thank you,
George
